noooob
hello noobie here i bought a flash red gti just over a week ago from a guy on here and have a couple of questions about it
1, how do you work the head light washers ?
2, mine has a nightmare with condensation and takes forever to de-mist so is this common
thanks jason
  • Replies 13
  • Views 2k
for the second point you might need to change the pollen filter :)
headlights are washed when the front window is washed too btw
andy's right about the pollen filter, but it could be a gromet is out somewhere too?
ok thanks can i get a filter from say halfords ?
the washers dont work with the screen are they powered by a fuse that may have blown ?
best to get a pollen filter from vw or at least a genuine one as they aint expensive :) and best to replace it with a genuine part because that way you know it will fit :)
Welcome :)
Is the condensation localised? (i.e, front passenger side, bootlid etc etc). makes it easier to diagnose.
Our Mk4 gets shit loads of condensation. moxture of leaking door seal and rear cluster seal failure i think :(
Hi and welcome x
i believe that the washer jets only work if the water bottle is full a certain amount.
this is true happened to me too. oh yeah and welcome :-)
Hiiiiiiiiiiiiiiiiiiiiiiiiiiiiii
Sorry I can't help!
and the washer leaver has to be held for more then 2 secs i think
ok thanks regards to the washers will try these test out at the weekend lol
and the condensation is everywhere for example i got in my car tonight was clear inside 10 secs later i couldnt see out any of the windows and the blowers wont shift it for like 15mins minimum also if i use a chamois sponge it fogs almost instantly after wipeing i have never had it this bad on any car before and I've had a few lol oh yeah and the centre of the windscreen wont seem to demist this could be a blower pipe has come off i guess ? i will check that out at the weekend
thanks jason
Sounds like theres definately a leak somewhere! I used to find them by sitting in the car whilst a mate sprayed the car with a hose and then having a feel around to see if there were any damp patches.
ok so changed the pollen filter saturday with a vw replacement ( the old one was black but still dry ) but the problem is still there so i got the missus to jet wash the polo with me in it no leaks anywhere ( i suspected the sunroof ) so then i pulled back the roof lining to check the hole where the aireal is but angain bone dry so now I'm back to square one and i have no idea what is causing all this condensation ?????? :?
