Ultimate G40 Engine
Well for me I'd love:
- Bored 1.5l diesel engine block
- Forged lower compression pistons
- Metal head gasket
- Lighten and balanced diesel crank
- Lightened and balanced fly wheel
- JP Race G40 gearbox
- KKK04 Turbo conversion
- Large K&N air filter
- Silicone Hoses
- 4 branch de-cat downpipe
- Bastuck exhaust system
- 51mm de-wedged throttle body
- Oil catch tank
- Ported GT inlet manifold
- 310cc Bosch Injectors
- SNS turbo chip
- Large front mounted intercooler
- Larger radiator
- Mocal oil cooler
- Baffled and heat sank sump
- G40 Ported and polished head
- Schrick high lift turbo cam
- Aqua mist injection
- NOS?
- Huge waste gate
Anyone want to add to the list?
What about enclosed throttle bodies and an Emerald Programmable ECU?
- Jimmy
Edited by JimmyB
  • Replies 66
  • Views 10.2k
Nick_S' engine for me... If staying supercharged that is.
That spec would shit gearboxes every couple of miles :lol:
I'd love to see someone build it though!
I might buy some lottery tickets and see what I can do.
What about a diesel 'box with long gears to take the power.
Oops, forgot:
- Vernier pulley
:D
How about having it mid mounted in a MK1 Derby driving the rear wheels.
jimmy, you've had far too long thinking about his :lol:
You're right, I have. But it would make one hell of a car! People in ferraris would not be best pleased.
Think of the BHP per ton!
Unless it was raining. Or there was a drop of water on the road :lol:
i'd like to see charger/ turbo combo, charger for low-mid and hhhuuuugggee turbo for top end. :unibrow:
what would be needed for this setup?
smaller pulley on the charger for the low down power? :paranoid:
roughly what BHP would u be looking?? iv heard a high power engine will easily push 220?
as for the super/turbo charger....just buy the 1.4 tsi and mod that! lol
Edited by captin_urbis
I'd say closer to 250bhp
ahhh what a nice thought :shock:
can you get a 4 branch on a turbo car?
why wouldnt you be able to?
The engine that Jimmy mentions is what was being built a while back, I would add to the list that the JP gearbox should include a LSD, and the oil flow increased to the final drive (subtle internal mod) as the one we built was torquey as hell!!!
Emerald would be the way forward
Power outputs; pick a figure comfortably over 230
Edited by HoppyGTi
well you only have one pipe coming out the turbo. so its a singel pipe
Edited by 13kpologt
*Nods head pretending to know everything being sayed*
the Classic "POWER" phrase is my input :D
what is that coment ment to mean?
Think he meant he doesnt know what peoples are talking about... and it was a jeremy clarkson kinda comment.... 'POWER!'
Whats that block again... something out of a seat van or something?
Big valve head?
Dont forget a serious clutch and bigger / thicker drives?
I think he means 'POOOOOWEEEER' Jeremy Clarkson's saying
Big valve head?
In fairness good point, there was a time when a decent paddle clutch used to get fryed pretty quickly in not a massive powered turbo G.....I wonder what Yoof runs in his rocket???
Id have the 1w diesel block with custom pistons with a 16v afh or cbr1000 head. Could keep the 40 lader on the standard pulleys then and keep it fast and relaible 8-)
Edited by shaun_89
Yeah Theres a couple of bits I've forgotten, obviously there wouldnt be a 4 branch, it would be a turbo manifold with a single pipe. Also: paddle clutch, limited slip diff, and like you say something would need to be done with the gearbox and driveshafts to take the pain! Turbo and supercharger wouldnt fit together unless your had a remote turbo like that mk3 jetta in pvw!
TSI technology........................hmmmmmmmmmmmmmmmm
Edited by HoppyGTi
