Ultimate G40 Engine
As for getting the power down I think some serious alterations would need to be made, front subframe, uprated bushes, dampening and rebound rate adjustables, rose joints and rear anti roll bar, rear discs, camber adjustable top mounts, decent brakes and some toyo r888s would be nice, maybe even graft in a synchro drive train to power all 4 wheels, why not eh? Well there is the cost of all this I guess.
  • Replies 66
  • Views 10.2k
Man you have been thinking.......................I could scupper your plans & just say why not build a mk1/2 Golf that would handle the power alot better & would be cheaper to build.
Ultimatley it depends on why you are doing it!!
If it simply a dream Olop......lets keep going!!!
ermmm how about -
nick s' engine spec but with 1 in the front - and
1 in the back:-)
3ltr G80 circa 350bhp
just a thought
KiZ
Why dream :-)
Although it's not my ultimate spec...
Direct Injection
Sequential Ignition
Individual Cyl. Knock control
Variable CR
Electro-Hydraulic Valvetrain (The Ultimate Cmashaft angle/lift at any given point- i.e F1 Spec)
And the rest would be made of chocolate and gummi bears. So when I get bored it's a tasty snack.
Why dream :-)
Direct Injection
Sequential Ignition
Variable CR
Clutch my man; what do you use as a matter of interest???
Helix Paddle- never heard of anyone having a problem with them either.
Being nosey really!! 8-)
While we dream about an almost impossible engine to build instead of using that engine why dont you just drop in something with more power to begin with??? it wouldnt be a G40 anyway with the diesel block VR6 ftw :D
can you use a deisel block on a petrol head.. like oil ports etc line up?
I,m busy with my ultimate polo engine :lol:
Motor:
1600er 16V G60,angefertigte Schmiedekolben,
freiprogrammierbare Motorsteuerung,
Ölspritzdüsen zur Kolbenbodenkühlung,
H-Schaftpleuel SCAT vom Audi 1,8T Motor,
Drehzahlfest bis 8200U/min,
1,6l Block,
umgeschweißter 16V Lupokopf,
Verdichtung 8,3:1
Einzeldrosselklappen vom Motorrad
this one is from Anreas.{germany}
my old engine
1.6i 16v G40
digifant g40
origenail block
6000rpm
9:1
new engine {under construction}
Owned by the dutch.... haha But I guess they're not G40 engines.
Edited by Iscariot
Very doubtful!
As for engine spec, what i kinda have now plus:
Big valvehead
vernier pulley
LSD
Subframe
nitrous
emerald ECU
water/methanol injection (kinda already have it but its being a bitch to plumb in :( )
The 1W route does sound bloody fantastic but its just getting the parts to begin with!
Well for me I'd love:
- Bored 1.5l diesel engine block
- Forged lower compression pistons
- Metal head gasket
- Lighten and balanced diesel crank
- Lightened and balanced fly wheel
- JP Race G40 gearbox
- KKK04 Turbo conversion
- Large K&N air filter
- Silicone Hoses
- 4 branch de-cat downpipe
- Bastuck exhaust system
- 51mm de-wedged throttle body
- Oil catch tank
- Ported GT inlet manifold
- 310cc Bosch Injectors
- SNS turbo chip
- Large front mounted intercooler
- Larger radiator
- Mocal oil cooler
- Baffled and heat sank sump
- G40 Ported and polished head
- Schrick high lift turbo cam
- Aqua mist injection
- NOS?
- Huge waste gate
Anyone want to add to the list?
What about enclosed throttle bodies and an Emerald Programmable ECU?
- Jimmy
I think I would just keep my £5k for something else and still build a motor with more power than that one for a 5th of the cost!!! haha. 300bhp FTW.
Well Theres a lot you can do, It is just a dream. But to non polo fans the polo is not the most desirable car it was a bit sneaky of Vw to supercharge the reliable little polo which has also proved quite tuneable too. Sure we could all buy something better, more comfortable etc. for less than what is regarded as the highest possible spec g40 but the point is that that polo g40 is a fun to drive go kart like car with a bit of poke and can also pack one hell of a power to weight ratio figure! I've heard the stories and I've seen the faces of those who choose to drive with more comfort and better quality as I glide past in my go-kart like granny wagon, thats the point, I think with that In mind the G40 can be more funny than fun. The car becomes almost comical in that is does poop on a lot of more modern cars. :)
Edited by JimmyB
I'm not on about buying somthing else, just on about not buying all the stuff in that rediculously priced shopping list.
'richard16vg40' is more along the right lines I think. The 16v head is relative piss to fit and should beat the crap out of any 8v head. Might be better off with a bike cylinder head but its a case of trapsing round scrapyards measuring a million heads for suitability. Custom pistons eliminate any combustion chamber issues.
As for a lower compression ratio, I think the standard G40 compression ratio is probably about right. I would use the crank out of the very early mk3 golf 1.6 and make some descent conrods for it. and bore it out to the biggest I dared with some custom pistons.
A well sized turbo and some decent mapping to boot.
With that lot I think I would be dissapointed with any less than 300bhp, hopefully it would make a lot more.
But you would need some sort of gearbox to run it through, and you would probably have to put it in the back of a polo to get it to hook up.
Polo's arent really a passion for me, so I couldnt be arsed doing it, but for the guys that want to make a lot of power from a standard block (I would use a 1l block for jokes!) then thats what I would do.
Very true, I think you'd be wise to chose a 16v head and a larger block, again it would be go fun to see more than 300bhp through the front wheels of an early polo. But as said before, its the gearbox issue that limits it! Whats the strongest early Vw gearbox you can get then?
I'm guessing the 1.9 turbo diesel box would be pretty strong?
Yeah but there's no 08x fitment 1.9 turbo diesel boxes. Really you need to convert to 02x style boxes for proper power, which may or may not involve chassis leg modifications not to mention probably custom driveshafts, etc etc. I think I'd give up at that point and just buy a Mk2 Golf.
gearbox wise its got to be the box from dogwoods mk3 hasn't it 8-)
Why, what box is he running? Ps everyone keeps mentioning nick_s what is the spec on his g?
Tommo FYI , i cant remember where i saw it but i have seen honda cbr1000 heads used. Cheers Burt
Yeah Theres a couple of bits I've forgotten, obviously there wouldnt be a 4 branch, it would be a turbo manifold with a single pipe. Also: paddle clutch, limited slip diff, and like you say something would need to be done with the gearbox and driveshafts to take the pain! Turbo and supercharger wouldnt fit together unless your had a remote turbo like that mk3 jetta in pvw!
i know theres gunna be some tuning boffins on here saying that jetta was stupid for having a remote charger, but for a no compramise built, what a cool and different idea
Mine is not too far away from your first post actually, minus the blower type, and fuel boosters :lol: If I were to put a K04 with my engine, 230-240bhp would be about the mark. Add a 'tickled' AFH head (with complimentary custom pistons/rods) into the equasion and 300bhp isn't unrealistic.
Massive power in a 86c polo aint my thing though, so won't be going into those routes. Much rather have a 20vT mk1 Golf which can handle that sort of power better.
And as for gearboxes, I have a stockpile as follows to cope with the torque monster casualties:
ATV
CEK
CHL
CZG
8P
(Broken AYZ and AHD to repair any of the above)
I can relate to some of the experiences,outsider i may seem. Certainly the funny as well as fun - nothing like a little old car taking the piss out of some V6 saloon who initially snubbed their nose at you..
I know nothing about G40 engines other than the obvious basics,but I've always wondered why people pump everything into them but keep the short stroke crank.
I do know the longer 1.4 ABD crank slots straight in,the deck height cant be the issue for those who put so much engineering in,and the leverage science cant be hard for the masters to understand.
Is it too much hassle? Something seems to be stopping it from being a popular mod to this engine. :?
I think some people enjoy the torque factor rather than balls out overall power. The G40 is a very short engine and can shift to 100mph quite comfortably. How ever there is room for improvement in the grand scheme of things :)
