Dash removal
Hi all
I am stripping the car down and thought I'd strip the dash to sell for a few quid. Thing is, I don't know how.
I removed all the little bits underneath and the vents and clocks and dials.
Now what? Can't find anything in Haynes.
Bolly
  • Views 1k
What car is it mate?
If its a 6n, have you removed the screws on the sides of the dash?
Sorry!
Mk3 Coupe.
Bolly
theres 3 10mm nuts in the engine bay behind the wiper motor
screws behind the lower centre console
one screw at either end at the bottom of the dash
one screw in the glovebox
one below the steering column on the left
could be a couple more, its a while since i removed one!
Done! Surprisingly easy!
Three bolts behing the wiper motor, ecu and above the heater matrix thing. Then, back inside hunting for all the screws. Some of these are in real hidden places. Just take your time and work it out slowly. I found the obvious ones, then is a case of pulling on the dash and seeing where it is still firm and fixed to the car.
Thanks Petsy!
