my door wont open
i have a problem with my polo 6n. my drivers door wont open through the inside neither the outside. anyone no what the problem could be? :?
  • Replies 13
  • Views 11.3k
try lifting the handle up when opening from the out side
does the key turn in the lock? or not move at all?
could be the doors frozen shut eventhough its unlocking. or could eb the locks broken. even though its never happened to me its ment to be quite common on 6ns.
if you use the search theres quite a few threads on broken/fixing locks. with all the part numbers.
what do you mean? :?
the key does turn in the lock and locks and opens properly is just the door that wont open from the inside or out. and it couldnt be the frozen becus it wos b4 12am at night and i had been using my car a few hours erlier to put on my angel lights and it the door was fine openng and closing properly.
so you can unlock and lock the door fine but not open it at all?
could be the mechanism is sticky and wont move or cables snapped.
if you remove to door trim you should be able to see whats happening [or not happeneing] inside.
possible all it needs is a clean and a bit of grease.
yep can unlock and lock the door properly with the key aswell as the central locking, but cant open it at all from either inside or out. isit complicated to remove the door trim even with the door closed?
thanks :thumbsup:
well normal youd do it with the door open. not sure if itll fit past the seat. could be quite awkward.
its normaly quite a straight forward job but by the door being closed could get a bit more tricky.
failing that could always climb in the otherside and drive to a garage.
was the door stiff to open before, my mum had this problem and i just wd40'd the hell out of it and it worked
yer. well ill try with my dad to see how i go first then probs the garage. thank mate
not that i remember really the door was fine as id use the car bout a few hours erlier. :?
funny thing, i just went and checked my car and the door opened fine :lol: lool. thanks anyways everyone. :thumbsup:
  • 1 year later...
mine is doing this now ! exactly what you had just passenger side it opens sometimes , then other times it doesnt ? did u find anything that helped ?
My brother's passenger door did this, he took the seat out and ripped out the door card..turned the mechanism had disconnected itself :/
