Bought a Polo today; Hey
Hey, I bought my first car today (a Polo). I just thought I'd introduce myself and my car as I reckon I'll be using the website a fair amount now.
My names Alex, I'm 18 and from Essex.
My Polo is an R Reg (1997) 1.4 model. It's metallic blue, got 121,000 miles on it. It has open air which is pretty awesome. Came with a years MOT and 6 months tax, set me back £700. I'll put some photos up once it has been valeted as the guy didn't have time to do it.
It all seems in good nick, got a few small problems with it: Front wheel bearings needs to be corrected. Back window water sprayer needs to be adjusted, Cigarette socket is broken and Central Locking doesn't work when opening the car.
- Any ideas on how much any of these problems would be to fix?
Edited by AColeman
  • Replies 14
  • Views 1.6k
Hello and welcome.
I know little of 6n Polos, so will just stick to saying hello :-)
hi there welcome..
hi! welcome! :) I'm sure somebody on here will be able help you with your problems
Thanks for the welcome - My knowledge on cars is pretty much non existent... What is a 6n Polo?
You're Polo is a 6n or (mk4 on here) 1995-1999 are 6n models.
Ahh okay, that makes sense. Thanks!
Welcome to Clubpolo Alex.
Adjusting the sprayer is a 2min job if its pointing the wrong way. You just stick a pin in the nozzle and move it to where you want it. The cigarette lighter may just have a blown fuse (30amp i think?).
As for the other two, not exactly sure what you mean by 'wheel bearing needs to be corrected' but if they're anything like mk3 items, they're a press fit which may mean a garage visit. The central locking may just be a wire off but I've never got to grips with one so I'm not exactly sure.
to my knowledge, the C/L is most likely the pump, which is behind the rear doorcard/back seat, bear in mind, this is as far as i know, I've got a mk3, so a 6n dude should be more knowledgeable than me :)
Welcome to Club Polo mate!
Its won't cost you more than £100 to get it all sorted out. As John 'Stresshead' has said above, the cigarette lighter might just be a fuse and adjusting the screen wash nozzle is as simple as putting a drowing pin,sewing pin in it and adjusting it to the correct psoition.
Central locking pumps are a common fault on these as they get wet and the like. I sold one last week for £20. It should be similar to that from a scrapyard or look in the for sale section on here.
The bearings are readily available from GSF and EuroCarParts if you require a new one. As said above its a press job so it will require you going to a garage to get the work carried out unless you have a press yourself.
Hope that helps!
Ussy
Ahh okay the sprayer sounds like it can be easily fixed, I'll grab a pin later and give that a go.
I'll buy a new fuse for the cigarette lighter and see if that fixes the problem, if it doesn't what would need to be done?
I spoke to a mate briefly about the C/L and he said that it was probably just the pump that needs to be replaced. I'll probably take a trip down to a scrapyard soon and see what I can find.
The bearings definitely need to be sorted by a garage, I don't think it's anything major though. I'm expecting a £20 job or less.
I'm probably gonna take a look at a new gear stick when I'm down the scrappie, guessing they won't be much?
Are there any quick cosmetic fixes you can suggest that don't cost much?
Thanks for all the help guys, appreciated.
well I assume the front wheel bearings need replacing as there's no adjustment or anything that can be done. It's going to cost more than £20, prob more like £100-£150. Bearings themselves are about £40-£50 for the parts and it's going to be a couple of hours labour.
My front wheel bearing needs doing too. To get it sorted you're looking at at least £50, because its an hours job plus the cost of the parts.
off topic but you are from colchester/ipswich ?? there like 15 miles apart ??
Edited by adam-polo
I got it wrong it isn't the bearing it's just the tracking that needs to be sorted... My bad.
Yer I live in Halstead which is about 20 minutes drive from Colchester. I think it was just a pre specified area that I just chose.
I'm gonna need to get it serviced does anybody know how much a standard service costs? I'm pretty sure my cam belt is going to need to be changed too just to be on the safe side - I've been told this is about £100?
Edited by AColeman
