How to remove front grill and badge from a 6n?
If someone could briefly explain how to go about this it would be much appreciated!
Edited by OLOP 1L
  • Views 4.7k
if you only want the grill, it literally just pops out, theres little push n click things, just have to press the little tag lightly with a screw driver or somethin n it pulls out, not sure about the badge, never removed, maybe some clips which u can get to from behind, however if your gonna paint could just mask it?
the badge is held in with 3 little clips. once the grill is off its obvious how to get it off.
just use a screw driver to push the tabs over, and it slides out.
All of them are clipped in, but watch what your doing when your clipping them out because they snap really easy ;)
Edited by Liam Polo 6N
Thanx lads !!
