polo 6n cam and ecu change
hi everyone, wonderin if anyone can help?
i've just bought a gt cam to go into my polo 1.0 6n,
i was offered the ecu from the same car aswell.....do i need it? don't know if it'll fit, or make a difference?
thanks
ben
  • Views 991
Won't fit and nope don't need it.
thanks man...
the cam will fit won't it? just have to set up the timing on my own.....the timing mark is out...lol
probably won't make a difference
thanks
Ben
the cam will fit in the head iirc but you will have major trouble getting it to run on the standard injection gear because the distributor will be at a different angle, plus the timing marks will be in the wrong place......
