Glass Removal
Hi All
How do I remove the rear glass and the little triangular bit in the doors on a mk3 coupe?
Many thanks
Bolly
  • Views 1.2k
I know how to remove the triangles in the doors, never done the rear glass though.
There is a screw on the top of the door and a bolt below the vertical separator. Undo these and the separator bit will come out (assuming the main glass is out :)). It was quite stiff on mine but it should come out. If you're selling to me then I won't need this separator part, so get it out however you can! I think the triangle bit will now pull out, although now I think of it I may not have actually taken it out, only the separator.
Hope this helps :)
I removed the separator, but its not budging.
No clue of the remove the rear quarters without damaging the seal.
Bolly
Edited by Bolly-Polo
lie on th rear bench with a mate outside n push with yr feet in the corners
