Painting MK5 stubby mirrors.
Hi Guys
Looking for a bit of help please.
Got hold of some MK5 stubby door mirros. I want to paint them black (currently silver the other red). Phoned up a bodyshop and he wants £30 to paint each case. :shock:. I'm not gonna pay £60 to get a pair of mirros painted!
So I've decided too have a shot at spraying them myself. Need a bit of help regarding prep work tho. Would appreicate any advice you can offer please on what I need to do before painting.
Dhali
  • Replies 8
Any help appreciated.
use a green scratchpad to rub them down all over. or 600grit sandpaper.its just to give the paint something to stick to.
just paint over the original colour, make sure you do it somewhere warm.
using lacquer?.....that bit i could never get right,........but you can use 2 pack paint mixed in a handy aerosol.no lacquer needed then.
hang them up with a bit of welding wire or similar so you dont have to touch them.
light even coats will come up real nice,
ok? good luck.
Edited by initialbmx
thanks bud :thumbsup:
orite mate,
basically you neeed to sand both down with sandpaper, that normally does the job, then use primer and then paint, make sure you get some quality paint, then if you can make sure you finish off with lacquer!!
hope this helped :-D
Lildub dhali
x
Rub them down with some sandpaper to remove the colour.
Make sure they are super smooth, then prime them with plastic primer. Rub the primer down with 2000grit sand paper until it's smooth.
Then get your colour and apply 2 mist coats just to seal the surface. Then apply 2 - 3 wet coats, but make sure the paint doesn't run!
Then lacquer them with a couple of mist coats, followed by 2 or 3 wet coats.
To finish, give them a good polish and buff with some compound.
Thanks for the help guys (and ladies).
I gave it a go on the weekend and they came out pretty good, much better than i expected :)
pics?
pics?
Haven't had a chance yet, will do soon bud.
