window winders...
how the hell do i get them off? :?
cheers,
Ryan.
  • Views 1.2k
What model is it?!
6n, you have to push the winder a certain way, depends really, tends to be the opposite side to the long section!
6n2, you can lift the rubber outer bit off and the get a Phillips screw driver in and unscrew and it will pull off!
Hope that's helped
What model is it?!
Hope that's helped
Its a 6n, you mean dont turn it, but like slide it off away from the long bit of the winder? if so, thats helped alot and cheers!
Ryan.
Yeah, once you have slid it up it should then be able to be pulled of, basically it's a latch type system.
cheers!
il give it a go tonight when i go up t garage :-)
had a quick go at getting them off tonight and at didnt work!
do they just need abit of persuasion or am i missing something?
where the handle is get a screwdriver or can use hand and push away from where the handle is, e.g handle facing up towards the top of the car push down on the plastic between the door card and handle
hope this helps
J
hope this helps
J
Sorted!
Thanks people :)
Ryan.
