Black Diamond Predator brake Pads *PRICE DROP*
Black Diamond Predator Brake pads
Bought these but i have the earlier design brake pads which require pp018 pads, the part number for these is PP097
They are this shape:
http://www.veedubmachine.co.uk/images/191698151B.jpg
I quote:
'Black diamond predator performance brake pads are an ultra low dust, high friction, high temperature compound with a heat transfer layer next to the backing plate to transfer heat away from the brake disc and pad enabling operating temperatures of slightly over 520deg with no fade at all. Black Diamond predator brake pads complement the black diamond disc range perfectly or if you wish you can gain extra braking performance by using the black diamond predator pads on their own with standard discs.'
Front axle set so 4 pads, unused in original box
£25 posted recorded delivery
Matt
Edited by Matt_Oldfield
  • Replies 8
  • Views 344
Would these fit a 6n2 with g60 carriers (I.e utilising 280mm discs)
Edited by Trunkz
Not sure mate dont know what the G60 pads are like!
Website shows a different part no. for G60 pads
B to the U M P
BUMP
BUMP Price Drop £25, need rid! have no use for them!
BUMP £20
BUMP £20
pm'd
SOLD
