Will 6n2 door cards fit into a 6n?
thinking this could look good.
would it work without too much hassle?
dunno if the speaker hole lines up right.
thanks man.
  • Replies 8
  • Views 1.3k
bump
Backs will swap straight over, fronts won't be as the handles don't line up.
ah gaay.
cheers anyway.
u might want to speak to jordan eff about this as I'm sure hes done it mate... i tried with no luck because i have windy windows =|
Po*low* has done it iirc in his 6n...
You need the metal rods that connect the door pulls to the door handles aswell as they're longer, then it fits fine. You'll also need to re-wire the electric mirrors if you have them.
Luke.
I Bent the rod, Lol but Your need door card, speaker tweeter, and the base that holds the speaker on the door i think thats it.
Knew i'd forgot something lol
