Primer (HELP)
well i had some rust so got rid of it and got it all ready to be sprayed
went down to halfords looked up paint code and what i needed.
sprayed it with the primer they said to use (red) and sprayed flash red.
came out the COMPLETE wrong colour i was thinking white primer?
any suggestions seems as halfords clearly have no idea.
  • Views 1.2k
halfords colours are wrong, and even vw paint will look different as the original paint has has x years of fading
yeah i know there going to be bit off coz of fading and that just want it as close as i can to the
same colour and the colour that came out is completely the wrong colour it looks brown tbh lol
when i sprayed my splitter i used there grey primer and got them to mix me my paint colur up with the paint code number found near the spare wheel and the finish was spot on!!
when it comes to red, yellow, white etc you need to use white primer as the red is slightly transparent so it wont cover the grey primer properly, just stay away from halfords paint its complete rubbish and their mixing schemes are quite poor
to be fair to them , i did some spray jobs on my tornado red 2F, code PY3D i think.
I used red primer and the cans they sell and it cam out quite good,
make sure your putting enough coats on to cover the dark primer.
Max
yeah, as the cars faded you wont get a close match... i considered buffing mine up the best i could then getting a match to the colour of the car in its current state rather than its original colour, if that makes sense?
Yeah i was going to get the car mopped after id done all the spraying so it came up all similar colour so ill try white primer
if it turns out rubbish and I'm not pleased ill just matt black the car aha ;)
