Remove Pillar Trim
Hello All,
I am trying to remove the window trim from my MK4 Polo 97 to run a wire up from my handsfree headunit mic. I have removed all the clips from the pillar, however can't seem to get the bottom to slot out for the life of me. Could somebody please tell me where I am going wrong and tell me how to do it?
Many thanks in advance,
Aaron
  • Views 1.4k
is this the A pillar your talking about ???
Yes, that would be the one :)
Yea thats hard to take out at the bottom in the end i just bent mine and snapped the clip at the bottom and its still sits in the nicely with out
i thought u had to remove the dash be seems bit extreme, just try and move it about in different directions
hope it helps
J
Yeah did that, managed to crack my winsdscreen, oops! It does appear like you have to remove the dash but i really cant be bothered to do that for the sake of a handsfree mic lol. Where abouts did you snap it to get it out. I cant work out if its not coming out because of the final clip (Which doesnt look like its catching) or something lower down.
right at the bottom where it sits next to the dash there is like a hook type thing which is straight and slides into a slot in the metal behind it
so if i snap that it should just come off then yeah?
yea right at the bottom of the trim
