Mk2 help please...
Just peeled off my passenger wing and even though the arch is caked in sealer/waxy stuff there's a good spot of rust thats holed in to the body a little. Theres an obvious water mark rust trail from the drainage point at the top (near aerial) right down to where its collected and rusted alot near the bottom (and eaten away the bottom of the wing).
Has anybody modified the drainage from where the battery and heater motor sits?
Any ideas what I should do? is it a case of sort the welding and then do a new thick coat of underseal?
  • Views 863
the drainage doesnt seem to be that much of a issue ..most cars are like that , the problem is when the bottom of the wing gets full of mud and leaves and sits wet forever , i do think its a bit naff how they designed it to collect water on the batt tray though
and yes ...cut out the rot , weld it up , prime , seam seal and paint or underseal
Ye bottom of wing definitely a problem, half tempted to box that off or at least weld on a guard so mud can't collect there.
Drainage-wise like I mentioned there's a clear water/rust trail right down near the A pillar from that drainage point. Was thinking of making a new cover that sits over the battery/heater motor area that runs to a small pipe out of original drainage hole and down under the car. Water wouldn't even touch the body that way, only to get in through bonnet vents.
yeh a sealed cover thats piped out the bottom would be nice , cant see youd make a nice factory looking effort though??
thing is its lasted 20 years like it ...not really a massive worry imo
