Am sure its a first
As am trying out a few thing i thought i would have a go at this conversion seen as I've not seen something like this befor so here we go just a few pieces to my puzzle
she started life as a 1.4 16v
but seen as this shell was to good to chop into I've started it in another 6n just to get it rite :p
well here goes its a mk2 16v kr lump B)
but i have had to cum to a holt cos the mk2 16v gearbox does not fit so i need a g60 bof or a abf hydrolic,cable change box
more to follow but for now thats as it stand but av got sum tricks up my sleve, :ph34r:
  • Replies 33
  • Views 7.4k
nice to see something different mate :thumbsup:
ok nice 1 m8 more to come
Dunno if its a first - but the first one iv seen :lol:
Looks a good job so far dude 8-)
should be a fast car once done.
I have never seen it done before.
I always wondered if it would be possible to fit a 1.8 16v in a mk2 polo
it will be a first trust me , well in the uk
and it will be fast as f**k
cheers
AV BEEN SORTING OUT MY LOOM 2DAY WHAT A BI=CH THE L8 MODEL 6N WIERING IS,
IF ANY 1 CAN HELP ME OUT PLZ COMMENT,
AM NOT SURE WERE TO ADD MY KR LOOM,
DO I ADD IT TO THE BK OF THESE PLUGS
OR DO I NEED TO PULL ALL THE 6N ENGINE LOOM OUT AND ADD IT TO THE BACK OF HERE
I've GOT A HYNES BUT AM JUST NOT SURE WHERE EXACT TO ADD IT
ALL HELP WOULD BE TOOK ON BOARD THANX
I'm assuimg your modifing all the mounts? what ones r u using? u guna use the golf subframe
yeah al be modding the mounts, but i wont be using the golf subframe al be mounting it like how the original polo engine is mounted
Not bad, like your chain of thoughts.....mk2 polo with a kr In....easy...well nit
easy but doable with the right knowhow :lol: do it! That would be intense!
Keeping my eye on this :thumbsup:
Good effort, nice to see someone having a try at something out of the norm. Those engine mounts look way off from being any use though whilst its sat on a tyre/jacks. I trust you are good with a welder?
Have you got that lump cheap? I would have got a 9A from a Corrado or ABF from a mk3 Golf if going to this much effort though.
Am back done a bit more modding av just got a 16v o2a gearbox now so i can go all the way now
av dne my mounts i just need to do a few more things to get the positioning rite but its getting there,
more to follow i just need to sort out my cammera
how you mounting the drivers side? Shafts? Cooling? Reckon that gearbox one will hold? could do with beefing up.....
As for the wiring, you need an early spec polo loom and a 90 spec kr loom if you ever hope to get this right.
You'll have to splice out the lighting and ancillaries from the polo loom as mk2's have two looms, one is the engine, one is the lights.
i know that mount wants beefing up its just like that till i get it all lined up,
but for the wiering av got it sorted av just pulled the 6n engine management wiers out and added the kr loom but seen as the kr engine loom dnt have much wiers av only spliced the ecu live and used the 6n loom to controll all the snsors job done
I was gonna say that gearbox mount will defiantly need beefy up. Is there any way you can move the engine across abit or do something to the chassis leg, those bolts look awfully close..
  • 4 months later...
YO peeps am back in the game yet againe, i lost alil intrest in my 1 off project but hay am back with 100% motivation so here goes just a few lil up dates on my behalf,lol
rite engine is fully in its new home,
its getting there just a few things to tidy up thought i would try out a new paint i found laying around at work,
also came accross a cheap ish set of tt leathers am not to keen on these but till i get my hands on a nice pair of buckets they will have to do
also while i was falling out of love with my conversion i thought hay what the heck get some power and yes i got me some.............
let the games begin,,,,,,,,,,, B)
looks like a fun little project you've got there :thumbsup: its what enjoying car modding is all about
what is that color you have found cant make my mind up wether its green or gold
it's not a first but still good to see it being done (there's one with a turbo on it too), personally i would of got an early polo wiring loom, they use the same fuse box as the late spec mk2 golfs so it would of made it plug and play wiring wise. have you got the engine sitting high enough? now your not running the injection you will have a lot of space above the engine to lift it up some more and give you more sump clearance, it might be worth thinking about while your in this early stage, the more clearance you have underneath with this conversion the better tbh
either way this is going to be one quick car when its done, fair play for getting stuck in and giving it a go yourself mate :thumbsup:
can you get a 1.9 diesel in there gear box wise it does narf give them krs a bit of tourque i take it thats a kr conversion i had one in me caddy i,ll try get the spec for yer as we had to fettle it for the adaption but was a lovely tight fit and nice gear change and boy did she move off them lights meeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeow
rite then were do i start well here goes ill big up all those with possitve comments,
and now the rest lets go,lol
the couler is nato green.
the conversion i have never seen a uk car with this engine in it + carbs so if there is another 1 pls point me in the direction of the man who has done it in a 6n polo not a mk2,3
anyway moving on nice and easy, the loom is all sorted i only had to chop the polo engine management out of the look leaving in the plugs for the sensors and all the ignition gear,the add the mk2 16v tci modual and the ecu you to controll the fueling and add my bike fuel am hay presto job done
as for sump clearence i need enuff space to fit my carbs under the hood so as I've got it now its ok as the car is lowerd about 60mm the sump is about 4 or so inches of the floor but when i mount the carbs ill re position it to suit the .
more updates to come stay tuned :-D 8-) :-)
Back in the mix againe this week i sortted out my rear mount
fixed the rad in place
added a few coolent hoses and power steering hoses
added my coil and a few lil bits and bats
also last but not least added my drivers side drive shaft
hope you all enjoy as there is alot more to come
^_^ -_- :p B)
Well here we go first start on the bike carbs
click the link and watch
Edited by bantan
Nice work mate, we had a set up like this lined up but when we worked it out the trouble wasn't worth the power that was going to come from it..
Which engine and box you using?
9A and O2J?
absolute fair play, i didn't think this would actually ever get anywhere but you have proven me wrong.
I'd like to see it on standard injection though, carbs is an easy option.
What you doing with regards to the clutch?
Seat cable/hydro conversion or fitting a mk5 polo pedal box with a hydraulic cylinder?
