think I've solved the problem with my polo
somwere between the fusbox and engine there seems to be a lose of power to the starter bit weird that but think i can solve it with a peice of wire from the conector on the starter motor and the wire coming of the ignition barrel
Edited by dubbegood
  • Views 827
You sure its not the ignition switch, I believe these are prone to going on polos, mines on its way out as well.
Push button start me thinks :)
na had a vw technition come round today and check the switch even he was a bit confused as to what was up with it as there is power from the switch to the fuse box but after that from fuse box to engine is no power
