1.3 6n won't start help!
just brought a 6n 1.3, and it won't start. got no spark so changed few things still no luck.
I've changed:
spark plugs
coil
swaped ht leads aswell
rotary arm.
not really sure what else to do, any ideas people??
cheers
any one??
try push starting it see if you have any look also is it just the spark missing
tryed already. just no spark, have fuel supply.
try taking the king lead off the dizzy and earth it on the box while someone cranks it over
Edited by brummymk4
if it still doesnt work i had the same thing with my lupo fuel but no spark, i changed all the thing you also did with no luck, had a look at the ecu and look like water had got into the ecu=broken.
new ecu and bingo sorted
also if you know someone with the same car engine code, will most prob have the same ecu see if you can borrow it to try on then you can see if that fixes it, before you pay out for an ecu.
hope this helps,
dan
Ok thanks i'll try that and let you know how i get on
