Kappas vs. Rainbows
So i was looking at upgrading my sounds, but, being the noob that i am, don't really know what amp to go for.
I found a JBL GTO-1004e, with 100w rms into 4 channels for a lovely wee price, and then thought about buying the Kappas (90w rms) to match it.
But a guy on here is selling a pair of Rainbows SL 165, (80w rms), for pretty much the same price, and I dont really know what to go for.
I know Rainbow are supposed to be good, but the Kappas are reduced, and are supposed to be 150, instead of 90.
I'm looking for a good bass, and looking to install a woofer at a later stage.
Kappas:
* 2-way 16.5cm Component speaker system includes mid-woofers, tweeters, and crossovers
* power range: 90 watts RMS
* Max Power: 270 watts
* Frequency response: 45-25,000 Hz
* sensitivity: 95 dB
* top-mount depth: 2-7/16"
* Impedence: 2-ohms
Rainbows:
* 2-way coaxial - 16.5cm (6.5")
* 62 / 60 mm Mounting depth (with/without ring)
* Max. power handling: 120W
* Nom. power handling: 80W
* Sensitivity : 90dB
* Frequency response: 50 - 22.000 Hz
* Crossover frequency: 4800Hz
* Grilles supplied.
* Sold as one pair of speakers
Opinions people?
Adam.
  • Views 819
I haven't heard either but on paper I'd choose the Kappas. Better freq response and sensitivity, plus they're comps so you can mount the tweeters away from the mids for better sound stage.
Agree. You're not comparing like-with-like, and a component setup is going to be a better option for sound quality than a co-ax. Kappas :)
