how do i remove rear bumper on 1997 polo?
hi guys, my 1997 vw polo has a big rust hole in the lower half of the rear bumper, ie the metal part. i have sourced an identical one in the same colour in great condition from a breakers but want to know how to get the rear bumper off. can i just remove the lower metal part on its own or does the whole bumper need to come off, and what tools are required? thanks in advance.
  • Views 5.1k
itll take bout 30-40 mins depending on bolts ok
open the boot theres four bolts sure youve seen them undo them, now check the inside of the wheels arches should be 4 bolts 2 either side 1 for top and bottem halfs now on the bottem corner of each side of the bottem half there are two more bolts mine had been painted over so a spanner couldnt fit over so get pair scizzors of screw driver and just hack away at the paint and then unbolt them
the top half should be able to pull at the arches to unhock the side of the bumper then just yank it off towards you cause it takes some to get it off some plastic bungs
once thats off you have to unscrew the plastic bungs to get the bottem half off and i think thats it
30-40 mins!? :-o does that include your dinner break!? 15-20 tops!
