strenghning breadvan chassis
i'm toying with the idea of turning my breadvan into a caddy style pick up, i've seen it done a few times but i was wondering how i would go about giving it back some of the suport that it will loose by cuting the roof off?
All i can think of at the min is a piece of scaf bar welded inside the rear quarters going at an upward angle from the bottom of the iner wheel arch to the b-pillow.
Any other ideas? Has any one here done one?
  • Views 1.3k
have you seen on pickups with a semicircle(ish) roll bar going round the back of the front cab and then two poles going 45 deg into the bed? that might help?!If your near me, i could make you one!
also, you could have it rusty with spotlights ontop!!! :lol:
Edited by diesel_ash
i've all but given up on the idea now, looking at pics of them they look too short to pull it off well.
That "roll" bar does feck all. Its just decorative, adds no real strengthening to the bed, just gives you somewhere to mount lamps/tie ladders.
Any reinforcement would need to be done to the under side ideally, if you look under a pick up the bed sits on 2 I beams.
Edited by Cymro
a full roll cage COULD do it, I'm not 100% sure tho
why not contact the havoc boys and ask them about there yellow one they made from a saloon?
I would suggest something along the lines of some box section in the sills to beef it up lentgh ways and possible soemthing running across the floor to give it rigidity then something to link up the bars in the sills to the rear end
yeah id imagine the sills need some hefty boxing , then a bar or two behind the seat to brace side to side
