rear window wont shut
Rear window (manual) when i wind window up just as it gets about 1 inch before its fully shut the thing stops and wont go anymore unless i lift the window and push it toward the left (as if it tilts just before its nearly fully shut) i took door panel off and the metal panel underneath but couldnt see anything obvious......any ideas?
  • Views 855
what i would try doing is, take off door card etc and there should be a braket that is holding your wondow, loosen that so the window can slide freely and wind the window up, if it does go up lower it again and tighten the bolts back up, thats what i did and it worked for me.
update if it works :)
CHEERS il try at weekend....i cant seem to see the bracket when i take the door card off do i have to take the metal doorcard off aswell......is the bracket behind the doorcard sokewher?
if you have a speaker in your door that that off and prob behind their if not, take off the metal panel but bag eveything and label if you dont think you will remember where it goes. also try moving window up and down and see if you can see anything moving and use that to find where the bracket is.
this case is common as some maybe your window is frozen and you've tried to move your window through force, it makes the window slip abit and as the window raises it rubs on the side and just does not want to go any further.
how did it go??
