Does anyone know...
The correct jet sizes for a mk2 1300 MH engine? I have searched but to no avail...
My polo has been running like crap for a few months now and the only thing I can put it down to is the jet sizes in the weber. I don't know what size engine the carb was originally for so I would like to get a correct sized set just to make sure.
Any help appreciated.
  • Views 1k
Anyone?
all covered in the weber faq
Yeah found it, cheers.
The answer is "I don't know yet"..
http://www.clubpolo.co.uk/forum/index.php?...93&hl=weber
The general view is that standard jets in the DMTR are ok but run rich. I would certainly agree with that, but I've also got a bigger GK inlet and a straight through exhaust. Hopefully I'll get it rolling roaded over the fairer months. I really don't think I'm getting good fuel mileage but then again Mr fascist Brown keeps putting up the price of petrol.
Edited by MacColl
Was going to go by this post.
If it helps, I'm running the following jets on a 1300, GK inlet, twin downpipe, standard cam, and they work fine, gettin revved fairly hard.
Primary: Main 100, air 155, idle 45, F22 emulsion
Secondary: Main 120, air 185, idle 70, F25 emulsion
We've run this on an air/fuel meter on the road, works fine. I know sec idle seems high, but power smooth through the range because of it. if I look around, I might find the jets I used on a 1400 nova SR, if you want. I pick them out with a pair of long-nosed pliers on the car.
Cheers!
So compared to standard...
Standard jets are..
Primary
idle 45
main 100
emulsion f22
air 155
Secondary
idle 70
main 115 (your saying 120?)
emulsion f30 ( your saying f25?)
air 185
Someone else suggested (Hypojam remember him)
Primary
idle?
main 105
emulsionf30
air 155
Secondary
idle?
main 115
emulsion f30
air(roughly)175
I take it your talking about the DMTR carb? Not the DMTL which I believe has a larger throat size.
I just don't have enough insight to know, hence why I would like to get a proper rolling road re-jetting session. I'd be interested to know what anyone thinks of that set up?
Edited by MacColl
