6n2 handbrake on 6n
Hi guys
Was gonna get a handbrake for my 6n so thought get a 6n2 one, was just curious, do I just need the trim or the whole mechanism?
Jon
  • Replies 10
  • Views 2k
straight fit all you need to do is cut a light bit out of the plastic surround got 1 on my polo
so all i need is the trim right? because wanted to get it on ebay, and the trim is cheaper than the whole handbrake....so wanted clarification on it.
sorry for being a complete idiot lool
alryt mate what do u have to cut out cuz I've just put 1 on mine and it doesnt fit too wel?
Na you need the hole lot i.e the whole hand brake the the bit that fits round your handbrake the surround you just need to make a cut out for it
Your need the 2nd 1
Your need the 2nd 1
so how would i install the handbrake onto my polo then using that? i thought with 1st one you could just change the trim around....
also would that handbrake fit the polo 6n at all? cheers sorry for all these questions....your the only one i know who has got a newer polo handbrake on their 6n lool
Edited by jonjon3003
Yer pull the plastic surround of the carpet and you see two 10mm bolts i think undo them then bolt the new 1 down witch is a straight fit then when you refit that plastic trim bit to the carpet when you let of the hand brake your see that its in the way so at the front cut a nicee little slot out and it will fit bang on
That's the bit you need to cut in the 1st photo on Polo96CL's link
