Central Locking
I went to try and fill up my car today but the cap wouldn't come off because it's locked. The central locking only half works as it is, it doesn't work when opening the car but it locks all the doors. So basically I need to get this sorted urgently so does anybody have any ideas on what I can do about it apart from taking it to the VW dealer and getting them to fix it? Also any idea how much they would charge to fix the central locking?
  • Views 1.4k
Alex mate, see if you can find TroubleStarter on here, his name is Ken and he fitted Zak's alarm and stereo stuff. Hes a master with problems like this, so drop him a PM and he'll probs be able to give you a hand :)
not sure how much they would charge but if you really need to get to the petrel cap you can just pull it hard till it opens i did this many times on mine when the central locking plays up.
I don't have central locking, but from what I've read, when you cant open the petrol cap, if you pull back the carpet on the right hand side of the boot (where the first aid kit is) you should be able to see the central locking pump and there should be a release handle.
I dont think the 6n has a release handle.
IIRC Panda on here on a similiar thread said you can take the pipe of the pump and blow/suck into it...should do the trick.
I don't really have a clue what I'm doing to be honest so I think it's probably not a good idea for me to go fiddling with it. I did go and look for a release handle but their definitely isn't one on mine. I don't really want to break the cap either. I'll get into contact with Ken, thanks for the help.
I'm not too sure what to do about this issue.
As far as I'm concerned I have two options:
1. Buy a used replacement pump and hope that solves the problem
2. Buy a remote locking kit: http://www.awesomeautomotive.co.uk/catalog...products_id=752
Any advice?
