Help guys MOT failure
HI guys had my MOT today on my 83 mk2 breadvan and it failed on a few things, some i expected and some that i didn't and dont understand.
Basically the first is the guy said the STEERING ARM was bent but i do not know which bit he means, all i can think of is the tie rod which is meant to be bent on one side. Any ideas please.
The second is that the headlights are not a beam or something he says they are coming out as a blur but he said it could just be that the bulbs are not fitted 100 percent correctly is this a common problem or does anyone know what it could be or is he chatting sh*t.
oh and the engine won't idle it just keeps cutting out it s a 1043 cc carb engine.
all help is much appreciated i also have to do the rear brakes and put on a new water pump but have all of the parts ready.
Thanks people.
Peter
Hi Peter.
Imo, it sounds like the guys chatting lots of shit. I've had it afew times where theyve said i need work doing when i didnt.
I cant comment on the steering arm but the lights being blurred because of ill fitted bulbs? I had a 89 polo breadvan so i know its real hard to fit the bulbs wrong. The alignment of the light can be out but its not really hard to get it sorted if you have a wall to work on.
I took my G40 for a MOT when it wouldnt idle for more than 5mins and it didnt fail. I told them before they started it wouldnt idle and they said 'ok, we'll take a look'.
If i was you, i'd go to another garage for a second opinion. The garage i use now isnt the closest to me but i know that they wont fuck me over by saying i need new bits when i dont.
Thanks for the help the guy seemed like a total nob yet he is the manager of the test station in kettering and its an in'n'out mot station.
for example i got an advisary on my rear shocks that i knew were fooked anyways and i have a sports shock kit ready to on in the near future. But all he did was push the back of the car down one and then said the rear shocks had a slightly reduced damping affect.
Plus he was hitting the bottom sill pretty hard to try and find damage luckily all he did was knock mud from the inside somewhere so was pleased with that as the body is fine.
The driver's steering arm is the curved rod that connects the rack to the strut. Note the use of the word curved, as in bent. If you want to impress him, inform it has that bend in so that it Ackermanns (ie when you do a tight turn, one wheel turns a bit more than the other, like a London Taxi). If he doesn't believe you, tell him to order one and see what shape it is when it comes in :)
I'd guess because your car's a bready, it's a Polo C? Have a look at the front of the headlamp and make sure there isn't a H and a number (sorry having a braindrained day so can't think what that number should be) molded in the glass, this means it should have the old style round headlight bulbs in, not the cylindrical halogens like a modern car. If this is the case, make sure you've got the right bulbs in, they're sat in the notch right (yeah, I've put them in upside down before), and again, explain that these are pre-halogen bulbs, so that's probably as good as the beam gets.
As for the idle.... that's an open ended question, that could be 101 things. Does it do it when hot or cold or both? In the first instance, make sure all your vac hoses are connected.
Stay away from this garage as they don't seem to know what they are talking about
As has been said the steering arm has a bend in it!
As for the head lights I think he is talking rubbish. Check that they are fitted but that's that, Maybe clean the lenses ?!? But as they probabbly are not Halogen then as standard they are fuzzy! :)
And as far as I am away he shouldn't be hitting the car in the way you describe. They should....
...visual inspection and then by finger/thumb pressure.
If necessary careful scraping or light tapping of the affected areas with the Corrosion Assessment Tool is permitted.
Take it somewhere else.. does this place charge for re-tests?
wire brush the arm and hammerite it black
the sight of clean paint will pleasure his thick mind,even though the part is correct and not a failure..
sounds like a moody tester tbh
thanks very much guys this is much appreciated and I've just ordered a new wishbone arm just incase to make sure he dunt mean that so what i will do is take the old out and compare the two if its fine il put the old one back and take the new one back to the shop and get my money back for something else.
i am also having trouble with the rear fog light it is not coming on i have changed the bulb and still nothing.
there is a 3 way rocker switch on the dash it sits in the middle and one side has a pic of dipped beam I'm guessing this is for driving light which my car didnt have until i put them in but i wired them to a new switch not knowing this was for them so i will wire them to that sum time and if i turn the switch the other way it does nothing is that for the fog light.
i am just replacing the water pump as the seals and maybe the pump are blown due to the fan switch not working and boiling the pump
also got my brother to renew my rear brake shoes ;D.
Peter.
