AEE bike carbs and MOT's
Right, i'll shortly be running bike carbs and i already have a de-cat. My emmisions will obviously be through the roof.
...what do you guys do? Do you replace the cat and de-tune the carbs to run lean?
...get a dodgy MOT?
...put the fuel injection back on? Or does it not run much above what it should do even with the carbs?
Help please!
  • Views 1.4k
What year's your car?
My emissions have always been through the floor,this 1.6 16v hardly gave a reading in october - though it was so lean top end it melted a piston soon after. But its still cleaner than most of the cat cars he gets through his bay,and was when it was an AEE.
Anyone saying these run dirty are either speculating or seen them poorly set up.
I dont know the deal with not having a cat fitted,some say it only has to pass the test,whilst others say the cat has to actually be there. I've never asked. Still,though I've not tried it myself,i believe i could run both a cat and the carbs without killing the cat. I was gonna try this with the '03 Golf catted tubular manifold but space and tube dimension were issues. I may still try a cat whenever i get back to the exhaust system.
It's a 1999 'V' reg.
So, are we thinking that if it's set up correctly, then it should pass the emissions? May it be worth having the cat refitted just in case? Or has it got no hope of passing either way?
I want to know how they determine what emissions a car SHOULD be putting out as well... i mean, does a certain age of car with a certain engine size fall into an emissions band or something?
Edited by leeds_finest
Dodgy MOT is the easiest thing to do mate. I'm gonna get flamed for saying that but i know plenty of people who do it!
I was worried about mine.. granted its before the 'cat test' but they said it was no problem what so ever.. just give it a good run before hand and put it in.. you might be suprised.
Speak to the test centre your going to use first for advice. In theory your car has to be fitted with a cat due to its age, even though there is a good chance it may pass emissions without one.
Tell them your situation and see what they say, at least it'll save you paying out for a test when they may be able to tell you before hand there is no way they can pass it
Good advice from Ash.
Note that the catalyst MOT emissions test also looks at air-fuel ratio to check that it's circa lambda 1 (AFR of 14.7:1) under the testable conditions. So you have to meet the HC and CO limits as well as have the fuelling correct - pissing around with the fuelling massively to get the HC or CO down isn't really possible.
