6N2 lights cant get them flush :(
I've read the topic on how to get you are 6n2 lights onto your 6n by making the centre whole bigger and trimming them down but they still dont sit flush. They sit a little bit flusher if i take that foam seal out that sits around the edge but i dont think thats part of the conversion.
Can anybody help.
Ben
  • Views 808
Just see what's fouling and stopping them from sitting flush, then keep trimming away at the problem area?
If you take the foam seal out, they will leak uncontrollably!. Just try removing parts that are fouling the lights fitting flush.
They don't sit flush because one of the bold threads sit in a plastic surround, this scrubs the car bodywork hole. Only thing to do is to shave down this surround, I can't remember exactly which one it is though!
