Wiring sub/amp
Hey, got a Polo 9n2
Just bought Sub/amp etc
anyone know the easiest route from the battery to inside the car to put the positive wire through?
any help, helps!
thanks - flownerdia
Edited by flownerdia
  • Views 1.6k
Hey, got a Polo 9n2
any help, helps!
thanks - flownerdia
your car is probably a 9n3 :thumbsup: not 9n2
the grommets are hard to find, basically i took my scuttle panel off, obvs take the wipers off first. they there is a grommet behind the scuttle panel, its hard to reach, i used a straightened radiator brush to pierce the cloth behind my grommet, yours may not have as much padding behind the dashboard unless you have aircon?
oh and i prefer to take the glove box out for ease of pulling and locating the power wire through.
any problems let me know :-)
nice one sir! how comes its a 9n3 and not 9n2? lol i have no idea tbh ...its 2006 06 plate.
but yeah, will try that this weekend and post another reply as to how it goes. thanks so much for you are advice..
PS: yes i do have air con
Another option if it's the same as a 9N...
There is the rear windscreen washer pipe that runs through the far front (top) of the passenger footwell, I drilled the hole out a bit and wired through there. It was easy peasy once I'd figured the route!
Edited by Lyons
thanks a mill, worked. i drilled the hole and got it thru easy.
thanx mate!!
