Urgent help required prepping bodywork
Hi everyone,
am hoping someone of here can help me, I've read through threads and threads on bodywork prep, I'm about to spray my car but dont want to sand it down using wet and dry. I've heard people mention orbital sanders....but what are they?
can anyone advise me on what they are? where i can get them from? and what sort of grade disc i should be using?
I'm quite confused by it all really but if i cut the prep time down then the car will get done quicker =D
thanks in advance
sean
  • Replies 8
  • Views 1.5k
My limitted understanding is you're better with a random orbital (dual action/DA) sander. Basically, it takes the elbow grease out of the job.
How you do it depends on whether you're going over exisiting paint, or bare-metalling.
thanks mate
so i need a random orbital DA sander. Ill be going over the existing paint so normally I would just wet and dry with something like 400/600
I'll happily bow to anyone with greater knowledge here, but last time I helped out do this sort of thing we keyed the paint up with a scotch pad and applied primer over it.
da sanders are okay and have a use
depends what you are doing and how mint you want it , for perfection the panels need to be blocked so they're dead straight /flat
if its just a matt black jobbie like everyone else on here then yeah the da is ideal ....240/320/400 should do it
yeah scotch briting smooth, undamaged paintwork is fine, just to put a key in it for the primer to stick to. chips/scratches in paint work need to be sanded out though, with a DA or wet and dry or however you wanna do it.
Also, its very easy to accidentally go through to the metal with a DA. Which can be a pain as you then have to prime it with etch/similar primer then rub it down again.
800grit is fine too, 400/600 id say was a bit too course just to get a key.
Using a scotch pad thing is good if the paint is perfect, but if theres some orange peel (which there often is even on factory paint) 800 helps to get rid of it and gives a better surface.
And you don't want to get it done quickly. They key is in the prep, mess that up and its going to look shit. Take your time and get it perfect or you will regret it when you notice all of the imperfections.
I spent hours n hours on mine, and still there are imperfections that piss me off. But it was a real good learning curve and I now know next time to spend even longer doing it.
Personally I'd steer away from a DA. In my experience its easier to fuck it up than it is to get it right. If you know what your doing its a good time saving tool but even then you really want to go at it with a block to make sure its nice and flat. Any corners cut in the prep work will be magnified in the paint work!
thanks for this guys, am glad it got some real answers from people who have done this before. I was going to paint my car Matt white but I am glad to say that I've come into a bit of money via a new business venture and will now be having the car professionally sprayed =D
