Question - Lower Grills 6n2
Is There Such Thing As Honeycomb Side Lower Grills Without Fog Holes , Can Find Loads With Hole But Didnt Know If They Make Them With No Holes ( Honeycomb )
Thanks ,
Pete
  • Replies 12
  • Views 1.9k
Yes I think you can, as my mate has them on his 1.0l polo 6N2, and he doesn't have fogs.
Best bet is to call VW and ask
You Sure He Doesnt Have Diamond ? I'm After Honeycomb ...
Anyone Know Where I Can Get A Pair Of Fogless (Outer) Lower Honeycomb Grills ?
Bump .
Honeycomb non fogs are pretty rare! Try ebay.de?
I've got a pair of standard non fogs if you want them
No Thanks , After Honeycomb .
Thanks Anyway
You can't get honeycomb lower non-foglight grilles. Only the "diamond" ones. I know because I've looked in to this myself and even gone and ordered the diamond ones from TPS, thinking they might be honeycomb. In short, you can't get an off-the-shelf non-foglight pair of grilles that match the GTi honeycomb front grille.
Ok Thanks Mate
why dont you just fit fog lights to your polo its a half hour job?? you just need to buy the oem switch from a gti or a golf etc with the multiple function for front and rear fogs. then the lights from ebay from a guy called lesbray or something, the lights are reps but i used them need are v.gd and your grills. the wirirng loom is already in just clipped into blanks behind the grills. hope this helps mate :D
I've seen a set on ebay before, came as a set with the middle grill. I'm in the same position, wasnt quick enough to snap them up. only ever seen them once though. there not a vag product. honeycombe only comes as a fog light option.
Already Brought Stuff Of Lesbray Before In The Past . Will Buy Fog Set And Wire In , Do I Need Any Wires Or Are They All There Ready To Use ?
just look behind your lower grills just remove the two + screws and look for a plug in connector. should be somwhere up near the wheel fella you'll need sum bulbs for them to as he doesnt provide them... dont forget to get the switch :D
