Have taken the rubstrips off...
As the title says, I took my rubstrips off the sides of my 6N... it went pretty well, only one bit of paint got damaged which I will be able to repair. My real problem is that on the drivers side, there is a sort of pale sandy coloured outline of where the strip was. I can't work out what happened, as it's perfectly smooth - it's not glue and there's no loss of paint. Has anyone got any ideas? Also, if I spray over the bits that it's happened to will it stand out? My car is silver by the way.
Thanks!
  • Views 728
Try polshing it out? use either g3 or t cut
it wil just be where paints faded bad mate, like liam said g3 or t-cut
It Sounds Like Dirt Has Got Under The Edge Of The Strips At Some Point And Ground Its Self Over Time To Basically Tan The Paint Work . Thats What It Sounds Like To Me .
Sounds like the last option to be honest... Although it's more than just an outline, despite what I said. It's the whole area that glue covered, looks almost like the glue has somehow dyed the paint. I'll try giving it a polish at the weekend either way, if not I'll give it a spray over when I paint my rusty arches maybe... Thanks for the help
