Various ICE bits n bobs
Got lots of stuff that I'm not using so might as well sell to fund my remap (and possible new intercooler
Rockford Fosgate Power sub:
12" DVC subwoofer. 1000w nominal 2000w peak (can handle lots more!). quite heavy (20kg!) Will produce ALOT of bass with the right amp. £100 - NOW £70
Rockford Fosgate EPX2 equaliser:
24 band equaliser to tune your ICE install to your exact requirements. A high end piece of kit consists of boot mounted box, RDAT (dash mounted control unit) and connecting wire. £200 (try and find one for less!) NOW £150
Rockford Fosgate gold plated battery terminal:
Gold plated positive battery terminal. 1 x 2awg input, 1 x 4awg input & 2 x 8awg input. Neaten up the wiring to your battery. £10 posted - NOW £5
Lanzar distribution block:
ideal if you have multiple amps. Brand new & still has protective film on. Blue base and clear perspex top. 4 x 2awg input/outputs & 2 x 4awg input/outputs. £10 posted. - NOW £5
Lanzar digital volt gauge:
Wires inline of the power cable to your amp(s). Blue base with clear perspex top. Blue digital display. 2 screws that hold the lid on are missing but the lid is firmly in place and doesnt interfere with the way the unit operates. 2awg input & output. £20 posted - NOW £15
Autoleads ANL fuse holder:
Ideal if you're running more power than a AGU fuse can handle. One locating bolt is missing but I'm sure its in the car. Abit scratched but nothing major. Can supply 1 of the following fuses free (300a, 150a & 100a). 2/1 awg input, 2 x 4awg outputs. £10 posted. - NOW £5
DB Audio 2awg power cable & ANL fuse holder:
Was fitted in my G but as i no longer have a stereo in it, i dont need this. Was long enough to fit in a mk3 so should fit a range of other vehicles. Cant remember the make of the fuse holder but it cost me £50 when it was new. has a slight crack which isnt very big on one end cap and still does what its supposed to. £35 posted. - NOW £25
FEELER: Rockford Fosgate T30001 monoblock amplifier:
I'll quite happily keep hold of this unless i get a good offer as it was uber expensive when i first brought it. Same amp i had in my GT at Polo show '07. 1500w @ 2ohm, 3000w @ 1ohm stable although the test certificate rated teh output higher than this! 2/0awg input. I ran this off the wiring available above and a bigger alternator/battery is recommended to get it running properly. Cost £1200 new - OFFERS
Pics can be obtained of any of the items for seriously interested people. Please PM me with any questions and i'll get back to you asap.
cheers :thumbsup:
Edited by stresshead
  • Replies 12
  • Views 552
TTT
Open to offers on all this stuff. If you want a pic of anything, please let me know.
(i haven't posted pics up of everything as my computer goes into melt down when i use photobucket :( )
Bump
anyone for anything?
Got any pics of the volt gauge?
TTT.
Will bung it on ebay if theres no takers?
going.................
how does the multiple amp disributer work? and pics please?
Allows you to split 1 power and 1 earth cable to 2 of each instead of running 2 of each cable (does that make sense?)
ill get a pic later today ;)
new prices if items are collected at springfest
any offer considered.
