Windows broken!
hey guys!
I have just bought a polo gti 6n2 and the windows are playing up!
The drivers side doesnt work atall, might just be unplugged and the passenger one will go down but it seems the motor doesnt have nough power to push it up so u have to give it a nudge now and again.
Any help? do i need a new motor etc?
cheers
  • Views 992
hey guys!
cheers
i had same problem with the power loss, chances are the bracket is broken, take off the door card and the stereo, there will be a braket on the main window frame one behind the stereo and one on the right and the corrosponding ones on the window, see if that moves back and forth, if so yeah your clip is broke, you can always drill through both clips ad bodge it or buy new set.
if its not that try loosening the cips holding the window so it slides frreely and raise the window to the top and then lower it and retighten the bolts, sometimes the window moves in the brakets and rubs like crazy on the outer rubber. give that all a go and if not message me. :))
mine was broke so this is how i fixed it
right sorry for not replying... u will have to go to VW them selves for 2 new switches for the drivers side part number V6X0 959 855 B0 1C 020F03C SWITCH at £17.28 each.. this should hopefully cure the problem if ure regulator aint dead but as mine was then i had to pay £30 for a 2nd hand one then there is the case of gettin the glass down to put the new regulator in... trick is undo the 6 torx screws on the motor and wind the armicher this will only wind the window down not up
if peeps get stuck i will dismantle mine tomoz and do a guide
tom
hey guys!
thanks for the response!
I manage to fix the passangers side easily as it had just fallen of the runners!
I then took off the drivers doorcard to find there wasnt a motor or regualtor atall and lots of wood lol
so looks like I'm after them now!
Also the switch on the drivers side for the passangers side window is broken!
can i buy the whole unit?
cheers
The two switches push out of the surround so each switch is seperate
