Replace Rear Wiper Motor
Good Morning,
I have just received in the post a new rear wiper motor. I am looking to replace mine today on a mk4 polo. I just want to make sure I remove it without making any further damage to the parts that are there! at the moment the wiper is completly seized I cant get it to move via the motor or by hand, the motor makes no noise what so ever to indicate that it is even trying to work.
To remove it I am assuming this so far:
Remove the two edge bolts either side of the motor (as the new one came with the bracket included aswel), Unplug water valvle and electric cable.
On the other side of the door.
Remove Tip off base of wiper.
Remove first bolt and pry of seized wiper with the help of a screwdriver and a lot of WD40?
Remove Second bolt which should release the motor?
Thats what I'm thinking at the moment but everything is pretty much seized so if i have to break the wiper blade then see be it.
Any tips/advice wouldnt go a miss, or even just to know I'm looking to do it correectly!
Many Thanks
Edited by Azy
  • Views 2.6k
do outside of the car first and if your taking it off why not just do away with it? :D
yeah mate, as above do the outside of the car first if your working on your own, it stops the whole unit spinning on the inside.
Its a pretty straight forward job tbh and it seems like you've covered everything you need to do.
  • 3 years later...
One of the easiest jobs,
just remember to clamp the rear squirter otherwise you WILL get fluid everywhere
but if your taking it off BY GOD don't put it back on
get yourself on eBAY
spend 99p and get a rubber blank grommet
and de-wiper your rear
good bit of weight reduction to as they weigh a surprising amount
