Coilovers bouncey as hell!
Yes it's very nice I nearly crashed taking my eyes off the road the road while my girlfriends boobs jumped up and down screaming eyes on the road pep ffs were gonna die!! Lol
  • Replies 31
  • Views 2.9k
ok so heres how the car was when coilies first fitted! ride was loverly and smooth lol stuck like shit to a blanket around corners and round abouts lol
heres how it stands now in buckaroo mode!
i am going to try cutting the bumpstops abit tomorrow and then wind the front down a tad to match the rears if it helps if not ill wind the rears up to match the fronts!
fingers crossed
Job done!!! Cutting the bump stops worked!!! Illy you are a genius!! Many thanks it's just as comfy as when I had the wrong ones on lol I just thought polos were uncomfy!!! Haha
Gladd you got it sorted :)
So if I removerd the bump stops would it A) be a good idea or just stupid and B) improve the ride even more? Also if I wind the rears up abit more will I be riding the bumpstops again as the spring will compress more and and Id be back in the same place again lol? If the hellers were to be taken out what affect would that do? Just looking for any extra comfort out of these Cheers!
Also what diff do low pro tyres make? Ie
more stiff and less bouncey???
the springs will be just as compressed with it wound down as they would if they were wound back up. all you are doing is winding the base that the spring is sitting on higher or lower.
and you would only be on the bump stops when you are right down, the higher up you go the further away from sitting on the bump stop you will be.
Cool cheers mate ill wind them up some more for my daily commute which is full of potholes and chunks of tarmac sqaushed into the potholes lol, if there still too stiff I in a month or so I'll probably end up selling them on and buying something abit better ie fk highsport or summit!
