Removing front and rear 6n bumpers
In a bit of a rush as have to be up early so haven't had time to have a great look but any guides on here on how to do it? my rear bumper is the two piece one? top bit is plastic, bottom is metal, does one have to come off to get the other off/vice versa?
cheers, any help will do. thanks again
  • Views 972
Yeah dude.
There is 4 screws at the top of the back bumper and a few either side in the arches. This will remove the top half of the bumper. IIRC there is one in the middle at the bottom and it will take the bottom half off. :thumbsup:
Edited by DubSingh-Dhali
Yeah i undone the 4 bolts across the top of the bumper and two each side of the arch, and i still cant get it off, it looks as if its got a flange or something under the bottom? ahh,
just went and had another look. took the ones out from the arches and the ones along the top, still wont budge. tried getting the bottom one off and every single bolt/screw is dead, snapped all 4 heads off the arch ones, then the bottom two are just solid. argh, - this is my bumper btw, beleive their different on different 6n's?
sorry for the triple post but had to bump it up,
got the back top one off, was on by some bung things on the bottom, just pulled it with a bit of force. bottom bit though, all 4 screw heads in the arch snapped, and then i couldnt even get the bottom two bolts off the bottom arent budging either, have used an impact wrench, all types of spanner and socket etc just isnt moving.
front one... bottom piece ended up snapping my screwdriver end, and top bit, one of the star keys is rounded off. ahhh, ffs.
