what a pile of balls!
ordered a steering heel boss off ebay like 2 weeks ago.
made sure it was the correct one for my car
made sure it had a wire for a horn
just came today, i got all excited, and it's too bloody small!
grrrrrrrr
  • Replies 11
  • Views 1.8k
The seller sent the wrong one? Or did you get it mixed up?
naah, i am definitely not wrong.
haha
the box says the right kinda car on it.
but it doesn't fit
Get in touch with the seller and they'll refund it?
yeeeah, have done.
i have bad luck with buying internet stuff, man
you got a link to it?
sounds like you have an early small spline boss, lucky for you all mk2s are fitted with a small spline rack. late mk2s have an adaptor collar fitted to make them large spline (same rule applies on the mk2f or mk3 as most people call it)
all you need to do is get this collar removed and you should be able to use the boss you have been sent. (you may need a bearing puller to get the collar off.)
yeeah, i did notice that it was a small one with a bigger one on it.
but i tried pulling it and it din't come come off =P
what's a bearing puller?
no, i don't think so, cos it's on ebay and the bid is ended
bearing puller...
bearing puller...
oh thankyou =]
meh, bearing pullers the easy way out. Hammer and flathead screwdriver ftw pikey styleee.
