hows this ?
got a little bored to day and decided to pop to halfords.........................
yes i know chav heaven and all that but hey need to fix my dash so i happened upon these L.E.D's
bit pricey 9.99 for what they are but i think they do an awesome transformation from this
(toggle switch's on right came from ebay 5 for 5.90 delivered and they look cool but shall be moving for dash to lower down where ash tray used to be as to much refection at night )
to this
Edited by braveheart
  • Replies 9
  • Views 1.9k
how did u do the 1's in your clocks wouldnt mind doin mine red
what you have to do is take out the normal bulbs which you don't need any more
then where you take them out from the top part just pops off all i did was use the sticky pads
to secure them in place ,the all you need is the live feed from your lights which is the brown wire is earth so you need to connect the black wires from leds to this and then connect the red wires from leds to the power feed from side lights which is grey with red tracer or grey with black tracer makes no difference you can do this with piggy back clips so no need to solder anything plus light switch just pops out so really easy to do
cheers andy
Like the ideas of toggle switches.
Might have to get some off ebay. Maybe get loads of blank switches from the scrappy and then change all of the crappy switches to toggles.
Hmmmm got me thinking.
I am making an on/off switch for my radiator fan, so might fit in nicely.
Max
cheers dude I'm changing the position of them tho cause there in the way for the new stereo so moving the to where the ash tray used to be i took the centre console out of mine and just putting a gaiter on me gear stick
Seems way too bright to me.
Wont do you any favors driving at night.
it is with toggle switchs there thats why I'm moving them lower down
my toggle switches face towards the passenger side when there on, still visible to the driver but not dazzling.
I did run blue clocks but the lights too bright for the amount of night driving i do, even using a thicker diffuser didnt work so went and got some green leds and used the original diffuser, perfect.
If those are the direct bulb replacement LED's you got robbed big style. they were £5 for 10 on ebay.
Edit: just realised yours are the fully illuminated ones, mine are LED tipped so not as bad anyway.
Edited by Cymro
after driving my car for awhile i decided the first mod i did for the lights i didnt like so i moved them so now i got this :-
car needs a good clean out lol also going to cover it in blue leather shortly
left to right at top :- fog side lights main lights
left to right bottom :- neons internal to be fitted lol push start and front fogs at some point
easier way of doing it is ask me for the ones i have sat in my old car that light up red
