6n2 lower grills
does anyone know how to remove the 6n2 lower grills - mainly the lower middle grill, i dont know how to take it, I've unscrewed the screw for the fog light surrounds and I've got them out, but i cant get the middle lwoer grill out
thanks for any help
  • Views 5.3k
There's about 10 black clips to gently unprise. use a really flat screwdriver.
here's a pic for referance.....
you can see the clips on the bottom in the image.
cheers, spraying my standard grills gloss black until i can afford to get gti lower grills
Makes it easier if you take the front bumper off first. Avoids breaking clips as well.
get a piece of strong string, loop it through and with a bit of a tug some of the clips should pop out
This is the best way to remove it, i took it off this way too. Don't bother taking the bumber off for it..... to much work
how much are gti honeycomb bumper grills?
guessing from vw is best option?
saves hunting around forever
Side grills are £8 ish each, and the centre is close to £30... from vw. but the honeycomb side grills only come with foglight holes.....
