Exhaust rattle confusion...
Right I have had a look under the car several times, and i am in two minds as to why my (standard) exhaust is rattling, both of which may well be wrong..
So it happens mainly when I am slowing (usually in 2nd, but from higher speeds it happens in other gears) and it is a hideous tinny rattle which sounds to be coming from the back. and i have shaken the rear silencer and i dont think it is any clamps or brackets.
The only two things i can think are either the baffles in the back-box, or the heatshield somewhere, but honestly they are (slightly) educated guesses.
Any help would be very much appreciated.. Cheers
  • Replies 8
  • Views 1.9k
It's a mk4...I'm yet to drive one that doesn't have an exhaust rattle of some kind.
Haha, fair point but this is a proper rattle like people look when i deccelerate and it happens, and it is royally pissing me off haha
mine had this and it was the heat shield so i ripped the lot of it off :)
The heatshield for the centre section yeah? is it not needed then?? haha
My Mk1 rattle was caused by the exhaust hitting the underbody of the car. That and my handbrake cable was hitting it somehow. Best bet, take it down a garage and stand there while they check, usually they wont charge you cuz it takes about 2mins and uses no parts.
thats the usual suspect of rattling..... along with the mount!
I had a rattling issue, put a backbox on and took the heatsheild off and it went away...2 weeks later it was back. Turned out the clamps that clamp the backbox to the mid silencer were loose.
My Mk4 at 3000rpm just sounds like a bora exhaust when it is completly standard? and its not blowing i have had it checked!! any ideas?
