You know you own a mk2 when....
Every bit of trim and furnishing rattles, creaks, squeaks or bangs
  • Replies 78
  • Views 8.2k
leaky petrol tank
its got round light s :-D
You reach into the boot and hit your head on the tailgate..
You look at it....
ahem... ;)
Sudden braking makes you cry.
you can open the bonnet and actually fix things.....
you can take the engine out 'just for fun'.....
its nothing a bit of carb cleaner can't fix.....
you know youve got a wicked little automobile!
When you can rob parts off it to fix your Mk1.
You know the true meaning of "Pierburg Hell".
Having to open the Bonnet is a rare occurance, but changing the petrol tank is a yearly job :biggrin:
when you go to fill it up and the pump just clicks due to the anti-syphon widget in the stupid filler neck
your door locks and handles freeze shut
the heater squeaks like fuck and drives you insane!
you have an oil leak just above the alternator
you have a hole in the battery tray
you have a fuel leak in the filler neck
you honestly can't believe how poor the lights are when dipped
Your speedo sounds like something out of Starwars when it's cold
Your heater matrix fan squeaks when it's cold
that pierburg word
you've had carb freezing
you want a twin light grill
you want a single light grill
you want derby lights and grill
you can fix most of these things without shelling out loads of cash.
speed 1 and 2 stops working on your fan
It's in bits spread around the garden after leading you to believe you are a fully fledge mechanic...
when you have to get your feeler blades out to set the points
when you push the brake pedal and nothing happens
when you push the brake pedal hard and a turtle head pops out
when you plant the brake pedal you lock up
when you turn round a roundabout in the wet with cold ditchfinders and piroette twice
when you only put a tenner worth of fuel in to save on weight
when you get in another car your amazed by the turbo wipers
the sun roof leaks! or it did on my old one!
when you can smoke people off the lights to 30mph
when you think everyone else is a girl because they have abs
when you fit your weber 32/34 and hear its first chirp
when someone asks you if thats a golf
when you crank the starter at the traffic lights because you thought the engine wasnt running (mk2 polos with leak free std exhausts are deceptively quiet)
Mono sound system and pennies holder in the cockpit.
x2 :x
You have a full set of tools in the door pocket (a 10/13mm spanner, a hammer, a flat screwdriver and a 5mm allen key), and can do any job on the car with them.
So true.......
x2 :x
Ballast resistor pack....
You're reppin the National Trust and Age Concern with the previous owner's choice of window sticker.
You know you've owned lots of mk2's when.....
You can use the brakes. Extra points for stopping at a traffic light that changed a bit too quick and nearly getting a TT go in the back of you.
