Mk3 Panels
Hi,
I found a drivers side wing thats currently on a Mk3 Breadvan, but my car is a Coupe, so just wondering whether it will still fit or if they're totally different, any tips for getting wings of aswell? as the car is in a scrapyard stacked on another car.
Thanks,
Dean.
  • Views 1.2k
Wing will fit, can't help with getting it of though, never took one of before :lol:
Cool, Cheers for that mate, good to know, Thanks.
Wing top bolts, a screw behind the wheel going straight up into the bottom of the wing, 4? bolts inside the wing behind the plastic liner that go into the A-pillar (will be caked in sealant) and 1 (I think) bolt at the bottom at the front.
There are two screws at the front down the bottom and one is behind the bumper so that will have to be removed first and there are like 4 under the bonnet i think at the top of the arch then there is one behind the wheel on the sill and the ones inside the wing to the A pillar like the guy above said not too hard of a job really shouldn't take more than half hour really i would of thought.
Helps if you take a lamp and a little blow torch. Can melt the sealer a bit quicker and easier.
