throttle positon senosr
reli need a throttle position sensor for mk3 gt. if anyone can help please.
thanks
  • Views 1.3k
i have a brand new one in the VW box with reciept £80
thats what vw quoted me for one, and i reli cant afford it, was hopin sum1 might hav1 cheaper on here.
i reli need a pay rise :(
thanks for the reply tho.
yeah i had too wait 2 weeks for it as it was on back order when i got it before christmas, but then found out while i was waiting it was my disi hall sender after swapping the disi. :roll:
would be cheeper buying a whole second hand Throttle body they go for abotu £15 -50 depending if they are flowed or standard/working etc
Edited by genesisGT
didnt think you could buy the TPS on its own, it has to be the whole throttle body as the TPS is factory set.
its just a fancy (expensive) variable resistor cymro.
its like old BMC disi's has a slot it goes in that matches the butterfly position so you cant really get it wrong then the 2 side bolts hold it in position.
yea I've alredi changed the whole thing, bout 2weeks ago. but it was one i got given when i got the car, so i dont no how much works its done reli.
i just cant believe its so expensive, for sumthin so small, another reason i dont wona get a brand new, is if it isn't the TPS thats the problem its abit of money wasted, specialy when i can't afford it.
cheers for the advice tho lads.
try changing the disi and checking the coil and take a plug out make sure its got a good strong spark before buying anything i would say.
