vw badge on back
woz just wondering how easy is it to remove the main vw badge on the tailgate as i wont to paint mine black???
  • Replies 12
  • Views 1.6k
on a 6n2?
Easy, just pull it off. If the glue is too strong, heat it up a little (hairdryer is handy for that). Simple!
The Rubber Seal Round The Outer Of The Badge In Not Glued So You Can Get A Credit Card (Old One) In Down Behind To Help It Off Once Heated .
Or try dental floss to ease it off with.
Just give it a good pull, they usually come off pretty easy
Try using fishing line like a cheese cutter to get it off safely without damaging paint. You can drill out the plastic lugs to remove the badge from the base plate / rubber backing. Then after painting glue badge back onto base plate with araldite on the lugs.
does the whole badge including the rubber and plastic backing come off or is it just the vw emblem?????
Whole thing comes off.
Just use a credit card.
nice one dude i presume its the same then for the "polo" badge letters.
Yeah The Same , But Be Carefull Not To Take Any Paint Of . You May Be Left With Some Sticky Which Is Easily Removed .
whats the best/ easiest way to get rid of the sticky shit?
ended up doing mine this morning, not gonna bother puttin the polo letters back on it looks better without. but all i done was poured hot (not boiling) water over the badge and letters and used fishing gut to slice through the adhesive, after that i used tar remover spray to get the rest of the sticky shit off.
