New member that might be buying his first Polo!
Hi all,
Just signed up in the hope of tapping the fountain of knowledge here.
I've been offered a P-reg Polo CL 1.9D by a colleague. They've inherited a 3 year old Mini so there's no home for it any longer. It's only got 53,000 miles on it(!) as it's been a school run car, and has only had one previous owner!
Was just wondering if anyone had any tips for me, what to look out for etc. I used to own a 98 Seat Ibiza Cupra 8V (the Mk2 with the same Polo dashboard) and loved it, so I have no qualms about buying a VW of this age.
Also, what sort of price do you reckon? I was thinking £700 - £800 max...
Apologies for unashamedly getting straight to the point, I'm looking at the car lunchtime and only came up with the idea to look on the forums about 20 minutes ago... Feel free to tell me where to go!
Thanks all!
Adam
  • Replies 20
  • Views 2.2k
Welcome.
Main thing is rust, normally drivers door area.
Service history etc, but TBH i dont hear many problems with the diesel engine itself.
£7/800 sounds about right, what colours the car?
Look on the rear arches for rust aswell :D
Steve.
53000 on a diesel! It's got over 4x that mileage in it I it's looked after! Best thing I can sugest is go on here www.uk-polos.net click the picture, then click I agree on the next page and then click mark iv on and there's a buyers guid in there!!!
Would give you a link but the website doesn't let you!
Thanks both.
It's that wonderful faded red that looks a bit pink. I'm thinking T-cut and a buffer attachment on the drill and I'll be sorted.
Main priority is that it runs well though. Want it as a run around more than anything else (even though I know I'll end up tarting it up a bit).
Great, thanks!
my old mans mates In the car trade and he swears By the method of G3ing it and then a really good wax and it should stay red for alot longer!
Edited by Pepe
Mk4 specific - Basically, look for rust everywhere, none working electrics (mainly windows and central locking). None working central locking is normally water ingress in the pneumatic pump that works the locks, which is behind the panel in the boot on the right. It's a case of a new pump, but they all do it, so a second hand one isn't easy to find.
Diesel specific - the 1.9 none turbo's a good dependable lump, so like any diesel, just look for smoke from the exhaust, like any derv , it 'll probably smoke a little on full chat, but anything else could say problems. Being a diesel, the front suspension has a lot of weight on it for a small car, so worn bushes and leaky shocks.
Also, if you're not that old, check your insurance as the engine size may cause them to give you a shock.
Again, thanks for the tips. If the central locking is kaput it's no biggy as it's only a 3 door, however leccy windows must work when there's no AC! I'll be sure to check.
Where can I pick up G3? Can't say I've noticed it in Halfords etc (not that I've ever looked for it). Is it trade only?
Meguiars G220 if your splashed with cash. Awesome bit of kit.
OK, I've just driven it and everything seems fine aside from the biting point on the clutch being quite high (like in the last 25% of the travel). Clutch is light, and when I deliberately went to 5th at 25 mph it did drag the engine revs down so it's not showing signs of slip.
Does anyone know if this is normal? Does the Polo have a high biting point?
Thanks!
Adam
Yes, really high bite! Whenever my mates drive my car, they get all confused like "where's the bite!" :lol:
But the bite is adjustable so not much to worry about, aslong as the clutch is soft and not slipping. Sounds like a win :thumbsup:
My clutch has been stiff as fuck ever since buying the car 3 years ago. Biting point is also very high and I couldn't stop stalling for the first week of ownership.
You need 2 10mm spanners and the clutch can be backeD off in about 3mins that's what I did and it's like a normal car now!!
Excellent, thanks everyone. Much appreciated.
I used to drive a Lexus IS200 until I put it in a ditch and the clutch was very different (understandably).
Will see if my deliberately low offer is accepted and let you know. :D
Cheers,
Adam
did you get the car then?
Not yet. It all looks good aside from the fact that the cambelt has never been changed and to me that's a ticking bomb.
Can anyone tell me how much it would be to replace, approximately? Obviously labour rates vary depending where you are...
do it yourself, a cambelt is about a tenner and it's about an hours work.
or go to a garage and get bummed by them.
Just been quoted £198 for the cambelt kit (includes tensioner), fitting and VAT...
And £58 to change the oil and filter.
Bear in mind I'm in Vauxhall, so getting spanked by London labour rates.
Have gone for the car, and am paying £550 for her. :D
Photo's to follow, before and after shots.
got to say if it was my £198, it CERTAINLY wouldn't get spent on labour... Shopping list would be more along the lines of:
Haynes manual.
Trolley jack.
Spanners etc. (depending on what you've got)
Cambelt/tensioner
Oil/filter/Coolant/Thermostat/Air filter
DIY Oil/filter change is about 20 quid, and 20 mins (including jacking/cleaning up)
Worth changing the coolant if it's unknown. There are garages that don't bother changing it(!) and while it's dry, you may as well change the thermostat.
Then it's a brake fluid change (again, a 30 minuter with a helper)
At least if you do all that stuff, you'll learn the way round the car, and you'll KNOW all the basic service stuff has ACTUALLY been done.... Probably all done for the £200 quid that your cambelt would have cost... Then the £58 that the oil change would have cost can either go in the toy fund, or fill the tank...
But that's just me!
Welcome
