Could you guys help?
I am looking at changing my car and was wondering how much I could realistically ask for it.
It is a 6n2 Polo GTi in Silver with 93,000 and is unfortunately registered as a Cat C on HPI.
The driver's door and wing are in a Satin Silver whilst the rest of the car is Reflex Silver as I didnt realise that their were two different shades of silver on the GTI's went I went to replace them. Also, the sill is a little buckled/bent near the front wheel arch. The front bumper also has a some paint peel due to the Motorway drive I often do. The car is in no way horrible to look at and straightening out the sill and spraying the door, wing and bumper is it would look really good. Most people don't even register the colour differences to be honest unless they are pointed out.
I have spent quite a lot on the car in the year I have used it. After buying the car with the dented driver's side I had to spend £702.71 getting it back onto the road. I then used it for a couple of months and the inevitable happens and the gearbox decided to go. I had the gearbox and clutch replaced last year in July at a cost of £622.36.
Whilst on holiday in January my dad booked it in for a service and had the following done: All filters, Spark plugs, Oil Change, Front Pads & Disks, Checked all fluid, Four tyres as previous owner had put really cheap tyres on. This all came to a massive £652.29
HT Leads were changed just after the service as one failed at another £50. I have also had to rear back box of the exhaust replaced although I currently cannot find the receipt.
I have other service history from the previous owner with a hell of a lot more spent on it. I also have the service book with VW service history up to 54,000. The Cambelt was changed in December 2007 at 71,000 so is good for a while yet.
I know this is alot of information, but I just wanted to show that despite it being Cat C, is has been looked after. I will be putting 12 Months MOT on it next month as it is due to run out.
If you haven't die from reading this yet, how much could I probably ask for it? I know I am likely to lose money on it, but if I can't get that much I am happy to keep it. Thanks
Here are some pictures...needs a clean :oops:
Edited by Lytescary
  • Views 1k
Pics will always help valuing a car. Also the spec will make a difference, if its got AC and leather its obviously gonna be worth more than one without. Depending on the damage I'd say its probably worth around £1,500. After all its a cat C car with mismatched panels, dent in the sill and paint damage on the bumper.
It has climate but does have leather. It's pretty much a standard GTi. If that's all I can get for it, I definately cannot afford to sell really as I have spent a bit of money on it over time and so would lose quite a bit. Bit of a bummer really lol
If I get the panels, bumper and sill sprayed and repaired, would I be able to cover the costs for it? I know it will make it slightly easier to sell, but would I get the money back in how much I was to pay to have this done?
Pictures added! :)
The problem is mate that you can pick up gti's now with similar mileage to yours that are not a cat c for around £2000-£2500 so no matter what you do or have done to your cat c car it will always have a limit as to what it will be worth. I think £1500-£2000 is about right for a cat c despite it being a nice car - best bet would be to keep it for a while given the money you have spent on it
Edited by mboyle4
You will loose money it on it, no matter what you do because its Cat C.
I'd rather sell it for a small loss than forking out more on spraying which is expensive and having an even greater loss come selling time.
