Rear windscreen wiper removal, what do you think?
Hey,
Was speaking to a mate today and he said how lots of people end up removing their rear windscreen wiper to give the rear of their car a cleaner, smooth look. He's got a tool to take mine out, and I think I fancy doing it. What do you guys think?
Cheeers!
Mark,
  • Replies 16
  • Views 3k
its if u want to or not. i always have. but the rear window does get very dirty. and what tool you need? if i remember ifs just a 13mm spanner needed and put a rubber grommit in its place. and block off the washer hose.
I think it will make the car look better...the rear of the car has been what I've liked the least about my car, I'm getting new number plates as they're a bit tatty, but I think removing the windscreen wiper will, like I said, make it look a lot smoother.
Yea, I can imagine it would get dirty...I guess if I do it i'll just have to give it a wash with a bucket of water every so often. How easy is it to put the wiper back after you've removed it?
Ah right, he had a tool of some sort, hadn't seen one like it before...but if all you need is a spanner, thats even easier. I read the rubber grommits can be bought from halfords cheap...how did you block off the washer hose?
Thanks,
refittin isnt hard. just dont damage anythin and make sure u reseal it. the smoother look part tho. on 6n thers a cut out for the wiper. so when u remove it ther will be the plastic blank missin as u cant make it stay on. unless u get another from a scrappy and fill in the hole and maybe add a bolt and bolt it through the car. thts the only problem i cam across when removin mine.
Personally I Prefer Without The Rear Wiper , Look Much Better .
Rear Window Does Get Dirty But That Doesnt Matter If You Clean Your Car Often .
Yea, that looks so much better in the photo. I'll do it lol, I'll just make sure I've got a clean sponge handy in the garage then to clean it. Thank you! :-)
I wouldn't worry about your rear screen getting dirty.
You should clean your car often enough so it'll be fine.
As for rain, just leave the rear heated screen on, or spray some RainX onto your screen.
standing water on the rear used to piss me off but like indy i just used rain-x that stuff is the shit, and the rear demister works a treat. reminds e i need some more of that rainx shit
Lol, yea...I've seen RainX before...good tip, thank you. Will take a trip to halfords tomorrow, :-)
Personally I've never used Rain-X, the demister just works wonders!
Whats this Rainx stuff. I've been having nightmares with having no rear wiper on the mk1. With the inside being steamed up due to a leak somewhere in the back and it raining I pretty much can't see a thing out the back. That and the lack of a passenger door mirror makes lane changes a bit of a nightmare.
It's this liquid stuff that you put on your windows, and then water just falls off basically. When it's raining and you're going fast enough you don't even need wipers :lol:
Does wear off though which is annoying.
I dont get why people complain they cant see out the back when its wet i can see everything clear enough not to reverse in stuff. Then when its dirty and u put the rear wiper on it just shows off that thick layer of dirt even more.
Agreed. I never use my rear wiper, and rarely use the demister. Think about all the van drivers who will never be able to see a thing in their non-existant rear-view mirror.
My Mate in his Lupo has no rear wiper but has concted the hose to the inside of the front VW badge so he can spray people i.e me when my window is down, its a cool idea.
Edited by blandy123
i was gonna add that as well but couldnt be arsed :lol:
i liked my rear wiper so it stays, give it a bit of class with a areo wiper :)
