6n2 Seatbelt Warning Light
Hi,
i've got a 6n2 polo and wondering if there is actually a seatbelt warning light on it. If I shine a light on the dash, i can see the symbol that would light up but it never has done in all the time i've had the car.
Also, slightly unrelated but, under the rear seats, behind the drivers side, there's a large black disc with some wires into it. does anyone know what that is?
I know this isn't related to styling but it is interior, so i think it's the right place for it. If not, please move to correct area.
Duey
  • Views 1.6k
There is no seat belt warning light.
I think the light you may be getting confused with is the airbag warning light.
thanks, but i don't think i'm confusing it with the airbag light because 1) the airbag light is in the same cluster as the speedo, the seatbelt one is in the rev guage, between the fuel light and the battery light. 2)the airbag light comes on when i turn ignition on then goes off.
btw, i've read your build thread, it looks ace! well done with it :)
The black disk with wires going into it under the back seat is your access hatch to your fuel pump, there's 3 screws securing it and then a large ring securing the pump into the tank.
I've yet to be in a 6n2 with the seatbelt warning light, my gf has a 6n2 GTI and that does not have it.
cheers panda, i've always wondered what that was!
and thanks to you both panda and indy231 for telling me there is no warning light (even though the outline is there!)
Regards
Duey
why dont you take a picture of this light and post it up?
because it never lights up, there's just an outline of what would light up if it actually DID light up and you can only see it if either a torch is skillfully aimed at it or in very bright sunlight, both of which are bad for taking pictures
Mine does have a seatbelt light, and it works. It's the saloon though, and is different from the hatchback.
Maybe it was an option?
